QUOTE(J P Stein @ Feb 7 2012, 11:15 AM)
It's junk in my book, I'd guess you also have spalling on your ring gear also.
The carburized surface of the gear has broken out in that spot. This is often caused by improper backlash thru wear, lubrication lack or failure, bearing wear.....3 involved or mis-set pinion depth. It ain't gonna get any better. Take a close look at your ring gear...off with the side plate. If it looks good, they may last for a while.
I would guess the scratches on the tooth face you see are from the ultra hard bits of flake off metal passing thru on their way to your drain plug. All the bits prolly didn't go there and aren't doing the rest of the gears any good.
I have to agree, and wish add, once the gear surface starts to spall, it will continue to erode and contaminate
the oil with particulates. There will be a temporary plateau of erosion, at which time, temperature and friction will increase,
and that feature will fail, unable to cope with the load.
I would not run that, especially with a V8. I would talk to Dr. Evil, if I were you.
Replace it, and sleep better....worked on the stress analysis of H60 intermediate and main gearboxes, monitoring gear crack propagation during
destructive testing, using sensors that detected the onset of friction with 20k samples per second data collection.
Even tracked the progressive wear caused by misalignment and destructive particulates causing further spalling.
Gear crack propagation to root happens so fast, (milliseconds).
One second the load is equal on intermating gear surfaces, then one fails, causing an increased cyclic load
worse condition than constant load) on adjacent teeth and catastrophic secondary failures follow very quickly after that.
...in a word...chunky...
