QUOTE(914four @ Feb 6 2012, 07:51 PM)
What is the best way to move the fuel pump from the 74 location to the 75/76 location with a stock fuel pump? Does anyone make an access cover that will work?
Kelvin
.... or Kelvin,
You can move the FP per the 75-76 Porsche Service Bulletin for 70-74 914s, which relocated it up behind the steering rack cover (not attached to it as some have done), with the FP attached next to where your fuel filter is up there & mounted next to the access hole into the front of the tunnel where the fuel lines daylight.
Since you should also change out the 35-40 year old plastic tunnel fuel lines with a set of SS ones (see Tangerine Racing for the proper set), you can also run the FP witing along in the tunnel too (the service bulletin in the 70's had them run behind the pass. rocker cover since they didn't tear open the tunnel back then).
AA sells an FP Relo hardware kit which is essential the same as what Porsche used to provide to their service & parts dept.s back in the day, which isn't too costly.
