jarbuthnot
Sep 2 2004, 06:54 PM
The engine is a brand new 2L. The hiccups are mostly in low gears at 3K-4K RPMs. My mechanic thinks this is due to the fact that he can't adjust the fuel injection mixture. He doesn't have the right equipment (a gas analyzer?). Does this sound right?
Cap'n Krusty
Sep 2 2004, 07:17 PM
Naaaahhhh. Does it happen at steady throttle? Look at the throttle switch. Check the points, the ground wire on the breaker plate, and the wiring to the distributor and coil. HTH, The Cap'n
jarbuthnot
Sep 3 2004, 12:20 AM
Thanks, Cap'n. I forgot to mention, I'm not mechanical. What is steady throttle?
lapuwali
Sep 3 2004, 01:06 AM
He means does it do it only while you're accelerating, or while you're just cruising along at a set speed?
redshift
Sep 3 2004, 01:53 AM
Bucking?
Sounds like the Throttle Position Switch.. it's an easy fix, Otto sent me a crappy one too.
M
Bleyseng
Sep 3 2004, 05:41 AM
He is not supposed to adjust the fuel fix as it is set by the factory. What injection parts are you using for the 2.0l? The injection off the 1.7L? The injectors are? What MPS and ECU?
All the parts and injection pieces must match or you will have problems.
It does sound like a TPS problem but at the wrong rpm.
Geoff
redshift
Sep 3 2004, 05:55 AM
Maybe Geoff... but she says low gears, and that is where that buck stands up!
Yank-Yank! Yank!
You know too much!
M
Bleyseng
Sep 3 2004, 08:44 AM
It is usually around 2500-3000rpms as you cruise in 3rd going from off throttle to on throttle due to the worn out traces in the TPS.
Bad transitions at higher rpms sometimes are due to bad A/F mix due to mixed up Djet parts in my experience.
Just shooting in the dark trying to guess what could be the problem.......
More info would help....
