George,
Remember that the steel inner dash ill have either holes or knockouts for all possible switch options for 914's, while the dash face material would only have holes punched for those used on your 914.
So if you still have the original factory face handy, or pix of it while still in, that will give you a clue as to how your 73 was set-up.
Early 70 ones had a dash mounted wiper/washer switch to the right of the steering column, while all had the cigar lighter to the right, and the optional rear window defroster was to the right of that. To the left of the column from L to R were the headlight switch, emergency flasher switch & optional foglight switch (if so equipped) - see pix below.
For foglight switches - the green center type was used 70 MY up thru Fall 72 builds of 73 MY, then switched to amber 73.5-ish through 76 - so depends upon the time of the 73 MY yours was built - see the VIN door jamb sticker for build month/year.
p914.com has good info on the various eqpt. nuances over MYs, as does Jeff Bowlsby's websites:
http://bowlsby.net/914/Classic/http://www.bowlsby.net/914/CanAm/These pix are from the O&H Forum's "The few, the rare...." nailed forum, of Steve G's late 73 MY all original 2L example:
Click to view attachment Click to view attachment .. sorry, I don't have one of the left of the column of this.
These pix are from an early 73 MY (8/72 build) showing the earlier foglight switch of John L's "Orangina" 2L example:
Click to view attachment Click to view attachment Click to view attachment Ignoring the dealer optioned rosewood dash face on my buddy's all original 1 owner 71, these show full detail of the earlier dash/switch set-up with the wiper switch FYI:
Click to view attachment Click to view attachmentHope these help put switches in place for your 73!
Maybe someone else can post a later amber foglight switch in place on a 73.5-76, & a dash face with the rear window defrost switch in the proper position?
Cheers!
Tom
