ChrisReale
May 2 2003, 10:53 PM
WTF?? It takes an 8 amp fuse. I went through three 8 amps, eack would spark and blow before I put in a 16 amp. It works now. Why was it blowing fuses. I want to make sure everything is ok, not just patch it over...idea's?
Dave_Darling
May 2 2003, 11:07 PM
Which fuse number? 11?
--DD
ChrisReale
May 2 2003, 11:11 PM
yes, number 11 second from the right
jonwatts
May 2 2003, 11:14 PM
Please post your fix for this problem. The hazzard circuit in a 914 probably gets more use than the headlights
Dave_Darling
May 2 2003, 11:56 PM
Crap... Why couldn't it be a 74+ car, with the current flow diagram that is easy to understand??
OK, OK...
Stuff that fuse #11 feeds:
Buzzer. (I assume this is under the passenger's seat.)
Emergency flasher switch.
Interior light.
That's it. So make sure that your interior light isn't unplugged, and make sure that the buzzer (whether undre the seat or up on top of the fuse panel, or wherever) isn't shorting out.
Then unplug the black/red wire from the hazard switch and see if that helps.
--DD
Dave Cawdrey
May 3 2003, 12:45 AM
Didn't you get a new interior light recently?
Drums66
May 3 2003, 10:02 AM
Sometimes it comes back to what you F....d with last!
Curvie Roadlover
May 3 2003, 04:22 PM
QUOTE(Drums66 @ May 3 2003, 08:02 AM)
So true. Always look at what you last messed with.
ChrisReale
May 3 2003, 05:29 PM
Well, since my interior light is MIA, that could be it
Dave_Darling
May 3 2003, 06:13 PM
Power for the light is always "hot". If the power wire is down behind the backpad and touching the floor pan (common when the light it MIA), it'll blow the fuse every time. Find the wire and tape up the end.
--DD
