QUOTE(rhodyguy @ Sep 5 2004, 10:28 AM)
forget the ford seleniod. it too will cease to solve the problem midway on a 600 mile drive at a rest stop in oregon.
There are two different problems, hot start or low voltage to the solenoid. The ford solenoid does
NOT help with hot start, only low voltage. You didn’t say which fix you needed.
BTW, I don't know if low voltage is a common problem with the 914, but it is with the bugs.
As far as a reliability issue I’ve only had the one in my bug since 1991. The only issue I’ve ever had is when I first installed it, I had too much strain on one wire and it broke at the connector. I’ve never even looked at my starter since then…so say 6 to 8000miles/yr, that’s at least around 75,000 trouble free miles.
I also have a good dozen or more in customer’s cars, some since the mid ‘90’s, never had to fix one yet.
But maybe I just have horseshoes up my butt.
