QUOTE(Cap'n Krusty @ Sep 5 2004, 04:56 PM)
It's rubber, not plastic. An experienced glass shop can set the glass in urethane and you're done with it. The Cap'n
Not the glass retaining strip, he's talking about the nylon slider that is part of the regulator and travels horizontally in the rail as the window raises and lowers.
I do not believe that is available separate from the regulator, I think you need to get used parts. I don't think it will be found on other makes, just hit up the classifieds for a used regulator and make sure they check that part is good for you.
