In reassemblying my '73 2.0 I realized after I had it almost together I forgot to put in lower sheet metal that goes under the cylinders and push rod tubes.
In order to put them in I'll have to loosen the heads to get the tubes out etc etc etc.
Got to thinking- how necessary are they? This car will spend its life in AZ with no heaters or exchangers and no cold weather. With the fan blowing air from the top will it run cooler or warmer without these in place?
What would happen if I didn't put these back in ??
