QUOTE(SLITS @ Feb 13 2012, 10:09 AM)
Bah ....
An anti-roll bar does not affect the ride of a vehicle until you load it ... as in a corner or possibly hitting a chuckhole.
The Brown Turd had an SC front end under it with a 2.4L six ... handled beautifully .. flat thru turns and wasn't tail happy any more than a stocker.
Ron,
While you are correct about a swaybar only effecting spring rate in cornering and not going straight down the road, you have missed my point.
I have an application where I'm trying to balance out a chassis with a very stiff front and a goal of a ride and good handling.
So if I keep the stiff front end, then I have to go stiff in the rear which will be a summation of coilover and swaybar rates. Since I'm trying to limit the ride stiffness, I have to go with a HUGE rear bar to achieve balance.
However, before committing to a plan, I'm trying to understand if the 23mm front bar is TOO STIFF and the best answer would be to JUNK it and go to a softer front bar.
In my initial calculations, to balance the front with the 23mm bar, I would need a total roll wheel rate that would be much stiffer than my V8 track car. This would NOT be an acceptable answer.
Best,
Terry
