qa1142
Sep 6 2004, 11:29 AM
Ok, my new 205 50 X 15's rub near full lock in both directions on right front only. Rubs on inner wheel well (torsion bar area).
What do i do?
machina
Sep 6 2004, 11:37 AM
Well, don't turn the wheel so damn far.
My 914 does this also and my 993 did it as well. Way it goes when you stuff the biggest possible tires under the car.
I think you can put some stops on the rack to limit the steering travel.
dr
Allan
Sep 6 2004, 11:40 AM
I run 205/55/16 and they will rub if you crank it all the way to the stop. I have just learned not to do it. Turns pretty tight anyway.
seanery
Sep 6 2004, 11:42 AM
Brad Roberts
Sep 6 2004, 01:32 PM
I would have your alignment checked with these tires on the car. I typically run more negative camber in our track cars on the right front because most of our tracks have left hand corners. More negative in the right front can cause rubbing.
B
