QUOTE(pilothyer @ Feb 13 2012, 11:03 PM)
I have a fuel loop set up for testing fuel pumps and adjusting pressure regulators, I would like to also test cold start valves and fuel injectors. I need to know what kind of voltage should be used to activate the injectors and/or the cold start valve for test purposes that would be as close as possible to actual running voltage. This is for D-jet with the 2.0 (green) injectors.
I wanted to domthe same, inwas thinking of 12 volts straight from the battery, I guest not!
