L-Jet is easier than D-Jet!
I'm a student to and had the same problem!
Than if you work on a tight budget:
There is a cam from WebCam in Cal that is compatible with fuel inj,
but run your mechanical lifters, the hydro lifters are
, even though it is suppose to work with mechanical lifters!
Caution: You need also the WebCam Cam gear with it!
Than, if you work on a tight budget the Mahle European pistons with 8:1 compression give you 12 hp but do not require other big upgrades.
Double valve springs are something nice to:
http://www.csp-shop.com/cgi-bin/cshop2/fro...Valve%20SpringsAlso the oil relive pistons from Weltmeister are helpful for autocross.
Then a counter balanced crankshaft
http://www.autoatlanta.com/porsche-parts/a...bsec=CrankshaftGood luck with your engine!
Would like to see more, when you go ahead!
