Sooooo....
Were doing "diagnostics"...
Right now dad thinks its the oil pan.. although this IS the second time we've put a gasket on the pan..... Its coming from the front of then engine and its a huge leak. I think its something bigger but We'll see...
Any of you SBC guys have an idea?
BTW, its stinkin quiet stupid "smog" exhaust..... Sounds like a 4 cylander... grrrrrrrr *takes hack saw* Mmmmm much betta...
The radiator has a wierd leak... when there is no pressure/vacume (ie radiator cap is off), the water will squirt out the blow off on the radiator cap... when running, all is peachy...... add a vacume plug with zip tie, no leak...
Got 2 mins on the cam... maaaybe... soooo 18 mo mins of run time, and I get to see my lumpy cam!!!!
the radiator fan is hard wired with a switch.. when the temp switch is installed it will be used as a ground, with the switch being a backup.
Anyone answer my oil question??
Ya, I have video.. lata....
