QUOTE(markyb @ Feb 15 2012, 05:31 PM)
QUOTE(76-914 @ Feb 15 2012, 07:08 PM)
get a seal puller, they're cheap and look like a bent screwdriver.
while we're on the subject of tools, any suggestions for digging out copper exhaust gaskets from the head? I surely don't want t damage the exhaust port!
Seal puller from FLAPS; good as gold and likely under $10
For the copper exhaust gaskets, I first start with a good 90 degree pick. Often times just a tiny bit of the gasket is sticking out past the port wall. Carefully grab it with a sharp pick and you can tug it out. If that fails, I have a VERY sharp chisel that I slowly tap at an angle to cut through the gasket. You have to be VERY careful but it's not that hard to do and then it just pops out. When using a chisel near a motor, you can't wield it like a neanderthal!!
