I am running 195/60 on the street and 205/50 autoxing. My street tires are very close to the inner fender well(trunk side/ inside of tire) and might even rub on hard coenering. the track tires definatley rub. This is more eveident on the passenger side than the driver side.
The only way I see to fix this is to take negative camber out or use spacers. Any other ideas?
What aligment settings are you using? If I remember I set the rear at .5 to 1 degrees less than the front. front being -1.5 to -2 if I remember correctly
