I left the battery in the car and leads connected over night. The following day, I found the battery had drained to 6v. The ignition switch was off, lights off and no radio. I did a continuity test of the pos pole and do not see a connection to ground. None of the proximal wires are hot. How do you identify the source of the drain?
Thanks,
L. McC
