QUOTE(Angelface01 @ Sep 7 2004, 10:36 AM)
it is running rough, especially around 4500 rpm and higher. Does the timing stay the same (27 degrees BTDC @ 3500) with the pertronix or does it change?
it's not -supposed- to change...
you didn't mention if you retimed after the installation; if you didn't, you must...
another possibility is that part of the installation is fouling the movement of the breaker plate...
