QUOTE(RickS @ Feb 19 2012, 07:31 PM)
Installed mark's excellent weather stripping around the front trunk. Fit great. Washed the car and found water in front trunk. I can easily pass a piece of paper between the fender and trunk edge. The gap is about a sixteenth for about six inches. Relocating the weather stripping doesn't help. It can only go up so high. ThePO installed a fat wiring harness which the trunk pressed down on which ran between the gap between the fender and firewall. The trunk may be slightly bowed up as a result causing this. Pushing down and trying to bend the edge down does no good because of the reinforcing beam. Any ideas? Take it to a body shop?
I know it's not ideal, but I could spot you some rubber to build up a strip to help close the gap. PM me if you want to try this.
-Mark
