I am having issue with my fresh rebuilt. One cylinder is not firing. I was having similar issues previously. I ruled out many options. I am fairly certain it is a carb issue.
I have weber 44 idf's, engine is 2258.
Cylinder 4 wasn't firing. The spark plug on that cylinder is fuel fouled. Engine backfires through exhaust at around 2000rpm
Here is what I have done so far-
compression test- all cyl 180+/- 5
changed spark plugs- no change
changed spark plug wires- no change
changed distributor- no change
swapped main jet stacks- no change
swapped 1,2 carb with 3,4 carb and now cyl 4 fires fine but cyl 1 now doesn't fire (see why I think its a carb issue)
made sure the carbs were synced- no change
checked to make sure all jets were properly sized, no clogged and no burrs.
I looked down the carb throat that wasn't firing when the engine was on and I do not see any fuel dripping.
Double checked to make sure float height on both carbs is the same.
Looked at the idle needle- looks ok to me
Any other ideas? I'm sure it some stupid thing that I am just overlooking.
