QUOTE(Valy @ Feb 21 2012, 09:03 PM)
Pressure plate should be straight and even. If not,you'll need to resurface it.
check the sun spring to be intact and not too much wear on the edge from the TO bearing.
when you resurface, take off the same amount of material from the pressure plate cage. This will maintain the same distance to the flywheel and won't require shims.
The To bearing needs to be replaced.
Thanks.. Just check and it's square flat surface ( laid a bar stock from side to side ) .
T/O bearing replace then..
