matthepcat
Feb 21 2012, 10:54 PM
I can't seem to remove the dash vent/heater controls.
Is there a trick to getting this out?
Thanks for those with the skills to help!
Matt
partwerks
Feb 21 2012, 11:08 PM
Are you talking the whole mechanism buried in the dash?
matthepcat
Feb 21 2012, 11:10 PM
Yes.
Not sure if there is a trick to it, as it does not just push out
partwerks
Feb 21 2012, 11:13 PM
Can't say I've looked in there lately, but I would guess it was put in before the dash was put on?
Maybe can take the cables loose and is the mounting bracket bolted on or something so that it can be dropped down through the dash or out the front??
kconway
Feb 21 2012, 11:17 PM
Disconnect cables under cowl from the trunk, remove mounting bolt, pull out of dash.
Forgot, pull out lights and disconnect spade connectors.
matthepcat
Feb 21 2012, 11:26 PM
QUOTE(kconway @ Feb 21 2012, 09:17 PM)
Ahhh. There is a mounting bolt?
The dash is an aftermarket wood dash, not factory.
So this mounting bolt is behind the dash on top?
partwerks
Feb 21 2012, 11:32 PM
From the sound of things, it would be somewhere around where the fresh air blower motor is I'm thinking??
Mike Bellis
Feb 21 2012, 11:46 PM
Bolt is behind control on front firewall. Get to it upside down under your dash.
matthepcat
Feb 21 2012, 11:58 PM
QUOTE(kg6dxn @ Feb 21 2012, 09:46 PM)
Thanks Mike.
matthepcat
Feb 22 2012, 02:59 PM
Finally got it out this morning.
One of the vent cables running into the front trunk is not accessible, so I had to remove it from the dash control panel.
I'm really glad that none of this is going back into the car.
Thanks guys for your help.
Matt
