So I am at the point where I am getting close to purchasing parts for my 2056 build. I am curious as to the best method for determining bearing size needed.
I measured the crank with a caliper and it is very close to stock specs. I would feel better doing the measurement with a micrometer for greater accuracy.
Do I just buy standard bearings if the crank falls with in stock specs? or if the crank is at the small end of tolerance do I see if .01" bearings still allow clearance?
Do I need to have a shop install the new brearings in the case assembled( so they are torqued) and check them with a dial bore guage for proper clearance?
