scotty b
Feb 22 2012, 10:12 PM
What have you found to be the best way to install ? I'll be installing Jim's engine next week ( hopefully )and being that it is freshly painted, and my first time installing a V8, I am thinking a carb plate and the cherry picker going through from the top and lifting the engine UP from the bottom
Not sure the cherry picker will even get that far under the car yet
RJMII
Feb 22 2012, 10:22 PM
lift the car up on the hoist, put the engine on jack stands... line the engine mount points up with a plumb bob, then lower the car down.
Mike Bellis
Feb 22 2012, 10:24 PM
The first time I used a cherry picker lifting the motor while the car was on a lift. Maybe 3-4 feet in the air. This allowed me to fab the engine cross bar. It was a Ford 5.0, nobody makes a kit.
Tha next time (Chevy), I installed it just like a T4. engine/tranny rolled into place and lifted up with 2 jacks.
RJMII
Feb 22 2012, 10:25 PM
or cherry picker method you described.
Andyrew
Feb 22 2012, 10:27 PM
From the top is NOT the way.
Engine/trani on a dolly, drop car down, install the 4 bolts....
computers4kids
Feb 22 2012, 10:35 PM
I like lowering the car down onto the engine, seems to work for me.
rick 918-S
Feb 22 2012, 10:36 PM
I built a rolling stand for mine. I jack the car up, roll the engine under it, and lower it down a little at a time until I have the bolts for the cross bar mount lined up. I set the car down, slip the bolts in and nut it up. Then just jack the car up far enough to get my stand out.
jmmotorsports
Feb 22 2012, 11:51 PM
I use this hydraulic lift cart. Keeps the engine and trans very stable,roll it under the car, lift it into position. Works great for pretty much any engine and trans combo you would want to put in a 914
Jerry
jimkelly
Feb 23 2012, 05:12 AM
ass up high : ) and furniture dolly
lower car to engine bar - then lift trans mounts to mounting points
andys
Feb 23 2012, 11:55 AM
Up from the bottom, if you have an adequate jack. I built my own dedicated jack as I knew I would have to measure and fabricate requiring many install/removals. This jack collapses to 4 1/2".
Andys
rohar
Feb 23 2012, 12:22 PM
QUOTE(andys @ Feb 23 2012, 09:55 AM)
Andys
That's brilliant! Why didn't I think of that?
