QUOTE(76-914 @ Feb 24 2012, 07:32 AM)
I run the mech oil pressure units, only. Easier to calibrate and reliable. I never have bought into the wussy fear of oil leaks. However I am afraid of elec sender erroneous readings.
Note to self. Check oil on LEVEL surface. When I checked yesterday, I was on what I thought was a slight slope. Sure does not take much to throw off the reading.
Now I can get back to worrying about the fact I am running AA pistons and cylinders.
Would anyone know the part no. for the right Keith Black pistons to use if you bore out your stock cylinders? 96mm I believe.
