QUOTE(hot_shoe914 @ Feb 24 2012, 07:53 AM)
a 140hp 2.0 is a PITA to drive on the street
Why?
How fast do you want to go on the street?
Faster than the other guy.
You have to use a cam that gives a narrower power band, with the power at the top end. Need to build an engine with a higher rev-range then stock and better heads then stock.
Jake had a combo that was street drivable with 140, but it was similar in price to a 2270. And at that point, why on earth do the 2.0 140?!
If you are not using stock injection, shoot for ~120 hp from a 1911 or 2056. In a 914, 120hp is a lot of fun, but on the freeway you can still be passed by minivans at will. A small motor 914 is a back roads car, not a freeway bandit.
Zach
