Prospectfarms
Feb 25 2012, 10:00 AM
Were connections between the hot-air metal ducts linking the H/E and the body originally supplied with gaskets?
If so, is there a source? If no source what's a good substitute?
While I'm asking, has anyone used foil tape or another material to seal the many seams of the hot-air system?
Bleyseng
Feb 25 2012, 11:47 AM
The only gaskets used that I know of were the ones at the HE to fan connection. Last time I bought them from AA for way too much but I used em as a template. Does make a difference to seal that connection. The rest should be just factory setup.
The little aluminum deflectors are nice to have too.
Mikey914
Feb 26 2012, 08:01 PM
I have a the ones in the engine tin as well as high temp silicone hose as well as a lower temp version that can be used on the other ducting
Prospectfarms
Feb 26 2012, 10:24 PM
QUOTE(Mikey914 @ Feb 26 2012, 09:01 PM)
Much obliged. You are on my list for HT silicon hot air hose as soon as I gather some some more aluminum cans. I found one of the "grommets" and am looking for the other one. Thanks.
Prospectfarms
Feb 26 2012, 10:34 PM
TheCabinetmaker
Feb 27 2012, 07:20 AM
"foil" duct tape should work fine (till ya go to take it off).
Prospectfarms
Feb 27 2012, 07:29 AM
QUOTE(vsg914 @ Feb 27 2012, 08:20 AM)
Yup, foil tape is sticky stuff -- thanks for your input Curtis.
Prospectfarms
Feb 27 2012, 07:32 AM
I have 'em. What are they for?
