Do I have to pull the tank to get to the fuel pump? Is it under the tank? Or, CAn I get to it from under the car?
Sorry, I missed that one. The fuel pump is accessible from underneath the engine bay on the passenger side. It hangs from a bracket screwed to the sheet metal of the engine compartment. It is a cylindrical, "in line" pump, though early stock pumps have three barbs on one side.
After that many years, I will promise that all the FI hoses are by now wasted. Ditto the vacuum and rubber brake lines. They may look sound, but they are not. You will chase many problems until they are replaced. Do it while you're still young and strong.
The plastic supply and return hoses exit the firewall underneath the engine bay as well.
Changing the plastic through-body hoses is no small job. These lines are not under FI system pressure and I have not changed them. Many people have converted those to SS hose routed through the center tunnel where the control cables live. This is recommended if you relocate the pump to a cooler location in the forward trunk where, so I understand, the OEM 75, 76 pumps were installed. I haven't felt the need to do that, either.
When I started working on my car I pulled the filter to drain the tank. When most the gas was out, I pulled the tank, cutting the rubber lines that were connecting it close to the tank, then cleaned and lined it with Red-kote. This was after I'd clogged some filters and burned up my original fuel pump.
