QUOTE(jim_hoyland @ Sep 11 2004, 07:23 PM)
The lock nut is tight, the cam turns correctly when I turn the key. When the door is closed, the cam is hitting something.
there's not much play in there, maybe you bend the glove box door hinge?
it has a little tab that is supposed to hit the lock part when the lock is in closed position, if that tab is bent it might prevent the lock from turning ...
Andy
