ape914
Feb 26 2012, 11:14 AM
where are failure points in the 12 volt power supplied to the auxilary air valve? i got no voltage on the wire that feeds the aux. air valve heater.
thanks
TheCabinetmaker
Feb 26 2012, 11:25 AM
Thats on the same circuit as the fuel pump. If the pump runs, the aar should have power. Check the plug at the relay board
tod914
Feb 26 2012, 12:10 PM
Aside from the shared relay, it also shares a fuse on that same board (On the 2.0). Can't recall which fuse it is Haynes has the diagram for it.
Tom
Feb 26 2012, 12:49 PM
Rear fuse.
Dr Evil
Feb 26 2012, 01:50 PM
also shares power with the heater blower fan.
Tom
Feb 26 2012, 02:05 PM
And the rear window defroster, if you have one.
Where did you check that you see that the AAR has no power? There is a plug near the AAR and I suspect there is where, but you need to check also at pin 12 of the 12 pin connector on the relay board.
Tom
