blitZ
Feb 26 2012, 01:56 PM
I developed a clunk while going on/off throttle and starting from a stop. I'm assuming it's a bad cvjoint. The inner drivers side has the most play in it, so I removed it. It doesn't appear damaged, however the outer race is a bit worn. It's uneven when I run my fingers along the grooves. Should it be replaced or just repacked?
jimkelly
Feb 26 2012, 02:02 PM
looks and sounds like you problem might be in your trans ??
that said, eric shea sells brand new cvs
pcar916
Feb 26 2012, 03:41 PM
Light grooving is acceptable but deep grooves can "clunk", especially when combined with other cv's in the same condition on the same axle. You should definitely take a look at both on any given axle since they're a "system". If they were installed at the same time and one is worn the other is likely worn too.
That one looks on the edge to me, although the resolution isn't quite high enough to show if there is galling (metal transfer) which is terminal.
Good luck!
Valy
Feb 26 2012, 10:36 PM
Visible wear is usually a bad sign on those.
Having said that, you can still reuse them until they're completely dead.
I ran clanking axles for 20k miles until I sold the car.
Krieger
Feb 26 2012, 10:49 PM
Did you try laying under the car and shaking the engine/trans, exhaust listening for a clunk? Could be a bad engine /trans mount.
blitZ
Feb 27 2012, 06:08 AM
QUOTE(Krieger @ Feb 26 2012, 11:49 PM)
Yes, I checked everything and have narrowed it down to the cv. Think I'll just replace it, while it's out..
Thanks folks.
