Full Version: 09 dist
GWN7
the 70 has a 09 distributor. Should I replace it? and what with? a 05? What years fit? Crane, in the 09 body? (Pertronix is out, because of the burnout factor/time to replace it when the magic smoke comes out)
GWN7
One off line suggestion I got was COMPUFIRE, thoughts?
Another was a Mallory distributor? Unilite with or without vac advance?
Bleyseng
The stock djet one works fine with the vacuum advance hose hooked up too.
Geoff
thesey914
agree.gif 1.8 distributor works well -even with carbs.
Walter
The stock electronic transistor Vanagon dizzy (off a 2 liter aircooled (=type 4) '79-81 T25 Vanagon) works best for the price that a used one costs!
You have then a better spark (40kV), Hall effect electronic pick-up and even vacuum advance to boot!
Greetings,
Walter
Bleyseng
Where is Holland do you live, Walter?
