Hey Gang,
Yanked the dash and all the gauges today and I had the 914 fuel/combo gauge side by side with the 911 combo gauge that will live in it's place. I have a couple of questions regarding the oil temp module and the oil pressure module for the 911 gauge.
I think the rest is fairly plug-n-play:
* Fuel gauge from the 914 combo gauge will be wired to the VDO GT style gauge in the radio slot - Check.
* Generator light to Generator light - Check
* Oil Light to Oil light - Check
* Handbrake light to Handbrake light - Check
Which leaves the oil temp module and the oil pressure modules. Each one has 3-pins so, in checking the 911 manual, wiring that should be fairly straight forward. The one question I had is about existing wires in the 914 loom. I seem to remember Andy yelling at me about the green wire in the back by the fuel pump being the oil temp sensor wire...
I'm using an alternator and ditching the relay board in the back. Are there wires in that board harness (Perry?) that I can use for this without running new wires at this time?
Anyone else use a 911 combo gauge in the left hole?
