I have several porsche parts in thier ORIGINAL PACKAGING!!
A German Rienz Lower gasket kit for a Porsche 356 or 912 UNOPENED #616.101.901.01 $ 30.00
( Upper kit is sold )
Have also German Glyco Rod Bearings in STD. #616.103.142.02 $ 28.00
and also PORSCHE Boxed O.E. .010 #616.103.142.52 $40.00
Ring Set (yes all 4) for the big Bore 86P's Made in Japan #PR1465 $25.00
Several Mahne oil filters, 4.00 each
4 Bosch W5AC spark plugs, $ 1.00 each
Clutch cable 6MM ENDS $ 10.00
German 10X965 fan belt. 4.00
German Belt 10x740 $4.00
And a engine block FACE PLATE only, with no serial numbers .Takes the press in seal.
SHOULD FIT 356b/356c/912 Probably fit earlier 356a $100.00
German Sachs throw out bearing #901.116.81.11 and replacement pilot bearing #111.105.313A for the gland nut,
for all 914's /912's and 1966-69 2.0 911's $75.00
Also some new and some used Lug Nuts 2.00 Each
And a used 912 cam shaft with no gear. 20.00
Heater box to body air tube $5.00
912 Speedo shows 58000 miles green numbers $25.0
Generator pulley both halves and the nut and shims all $30.00
2 used gas springs about 13" length $7 each
1 Carb kit 616.108.902.02 $12.00
3 air filters Mahne for Solex $5.00 each
Both German Elring Crank seals with Hi Temp Viton for the Main both for $12.00
If it is still listed it is still available. I update as they sell
mike 619.204.38 zero zero
If the ad is here, their still available, i edit as they sell
i DO NOT TEXT
  • it's NOT ok to contact this poster with services or other commercial interests
View the full article
THIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
