oldschool
Feb 27 2012, 04:01 PM
OK so I'm ready to drop the motor I got a copy of the bird list...on how to drop the motor....So I'm trying to remove the front motor mounts bolts, and they keep on spinning
how do I even get a wrench
in there.
..waiting for a answer
'73-914kid
Feb 27 2012, 04:06 PM
The motor mount bar that connects to the chassis right? Put a socket on top, and a wrench on bottom..and remove bolt....
Not sure what size, thee are are Jaime, but is gave me one heluva time, as both sides had different bolt head sizes...
Jeffs9146
Feb 27 2012, 04:09 PM
It shouldn't be that hard! I use a offset wrench that has a bend at the ends and sits down into the U-bracket.
I have even gotten a short socket on it!
oldschool
Feb 27 2012, 04:10 PM
QUOTE('73-914kid @ Feb 27 2012, 02:06 PM)
I KNOW THAT.... but how do I get one in there from the top ?
Jeffs9146
Feb 27 2012, 04:11 PM
QUOTE(oldschool @ Feb 27 2012, 02:10 PM)
You don't you have to do it from under the car!
Jeffs9146
Feb 27 2012, 04:12 PM
I like to just put the top wrench on while under the car and use an impact wrench to zip the bottom bolt off!
oldschool
Just that I can't seem to find a good opening on the driver side?
Jeffs9146
Feb 27 2012, 04:21 PM
Just set the wrench over the bolt up here and loosen from the bottom!
If you just cant do it you can remove the H/E to gain some room!
PS: the one in this photo is upside down! I got it from the Pelican!
Feb 27 2012, 04:27 PM
QUOTE(oldschool @ Feb 27 2012, 02:01 PM)
http://www.914world.com/specs/tech_engdrop1.php
sanddog
Feb 27 2012, 04:33 PM
Just went through this Saturday when dropped my engine! For some reason all instructions I have seen don't say that there is a top nut ( 15mm ) that you have to secure with a wrench while turning bottom 14mm bolt outboard engine mount connections You got to have the wheels off and get your head up there or else do it by braille. Helps to have extra set of hands.
I also secured the engine mount bar with a jammed in 2x4 to keep it from falling when last bolt out, its is a little heavy.
Got my engine out with only that as an issue and everything disconnected except for the a long ground strap to chassis. Somehow overlooked that.
Good luck!
TheCabinetmaker
Feb 27 2012, 04:44 PM
QUOTE(Jeffs9146 @ Feb 27 2012, 04:21 PM)
That is the way the bolt is susposed to be. It keeps the nut and the threads from getting buggered up when you run over something.
etcmss
Feb 27 2012, 04:47 PM
a deep socket on the top with ratchet and a combination or ratchet-socket on the bottom. Not that hard to get access. Its the cold floor.
Gary
oldschool
Feb 27 2012, 04:53 PM
stugray
Feb 27 2012, 05:49 PM
I have found it is always easier to remove the engine AFTER removing the exhaust.
Where do you think half of all the dents & scrapes on the HE comes from?
Trying to remove the engine with it still attached.
Stu
Feb 27 2012, 06:14 PM
QUOTE(vsg914 @ Feb 27 2012, 02:44 PM)
Bolt head on the bottom gives you more room ...
Jeffs9146
Feb 27 2012, 06:22 PM
QUOTE(SirAndy @ Feb 27 2012, 04:14 PM)
I am sure you are right!!
I have seen it both ways!
It is a bit harder to install the motor that way. If you do it with the bolt head on top you can just jack the motor onto the bolt and thread on the nut.
ThePaintedMan
Feb 27 2012, 10:44 PM
This is going to sound obtuse... but why is this so hard? I did mine in a little over 2 hours and that was mostly just to stop and document with photos. Not sure what you're doing different?
914itis
Feb 27 2012, 11:02 PM
I dropped one qlast weekend and the bolt was so rusty I had to cut the mount holder, but in my case the tub is shot and oi will cut it up anyway
oldschool
Feb 28 2012, 12:35 AM
QUOTE(ThePaintedMan @ Feb 27 2012, 08:44 PM)
Not hard, just the first time for me....the one bolt (driver side) I wasn't sure how to get the socket in there.
but thanks to uall...its done.
76-914
Feb 28 2012, 11:01 AM
And just like the rest of us, now that you've done it once you too are an expert.
ThePaintedMan
Feb 28 2012, 07:38 PM
Yep, nice job bud. Its deceivingly simple. What, you mean four bolts hold all of this in there? My neighbors still don't believe me. And this is also what I tell people when they ask me why I bought that "piece of crap." 30-35 mpg and if the engine does die, I can change it out after work in enough time to get to work/school the next day!
rwilner
Feb 29 2012, 07:04 AM
QUOTE(ThePaintedMan @ Feb 28 2012, 08:38 PM)
IF four bolts are holding your eng/trans to your car...I think yours is missing two bolts
ThePaintedMan
Feb 29 2012, 10:26 AM
Two main engine bar bolts, two main transmission bolts. I didn't remove the brackets for the engine bar bolts. 2+2=4?
76-914
Feb 29 2012, 11:37 AM
i think he was refering to the two at the rear of the tranny. hence, his engine/tranny statement!
