Engine: '74 Djet 2.0
Weather: sunny mid 60s
Drove my daughter to work today at 11:30am
Car was driving great - feeling strong, no major hiccups
Drove about 25 miles (35 min or so) and stopped at the mall so she could run in and get some supplies. I let the car idle while waiting but after about 10 minutes, it slowly died
I tried to restart and no luck. Seemed like a fuel issue to me so I turned the key on and off a few times to verify the pump was running. It was.
Got out and took a closer look. Lucky for me the PO had had the fuel pump hot wired to the coil. I have been running without this wire connected but never bothered removing it altogether. I turned the key to the ON position and connected the wire to the coil. The pump ran and I could see air moving through the fuel lines. I ran it for a few moments and then tried starting the car. Fired right up - with wire to coil.
So I then drove my daughter to her workplace and on to home. Car was not as strong feeling as before and would not rev over 4000 rpm.
Got home, disconnected the hot wire, and tried to start it. Fired right up. Shut it off and went inside to get some work done.
At 3:45 this afternoon, went to pick up my youngest daughter from school. Hot wire disconnected and the car started right up. Drove to her school - about a 10 min drive - and it felt strong. On the way back home, started feeling sluggish again. Difficult to reach 4k rpm.
Any ideas on what may be going on?
Seems odd that it works for a while just fine and then starts to deteriorate.
Suggestions on what to check are very welcome!
thanks.
