Full Version: Got a project
J P Stein
TimT
early or late hub? fine or coarse spline?
inquiring minds want to know
J P Stein
Don't matter, long as it ain't bent.
J P Stein
OK, it's just a wheel mounting unit. I bought some Fuch that need *some* work. I'm setting up a thingy that will turn the wheel at about 50rpm.
Plan A was the hub...plan B is a rear rotor....I gots one of those, but the hub would make the set up easier. So all that has to be correct is the stud spacing.
Someone must have one........
