QUOTE(gothspeed @ Feb 29 2012, 01:53 PM)
I have an indicator that will not flash .....
That's a different scenario ...
When the relay goes bad, the indicator light will flash once or twice and then *both* lights will flash, albeit very dim.
In some cases, reving the engine above 2500 rpm will "bump" the relay and the indicator light starts flashing correctly.
If you do not have any indicator lights at all, i would suspect something else besides the relay.
