FI set-ups off ebay are usually sub $200, and generally less because they are always incomplete and mostly junk parts. They are a huge gamble and unknown, don't believe it when you are told, 'the FI worked great, I just wanted carbs more'. The FI systems were only removed because they didn't work in the first place right? You would have to get multple systems to even have a chance of getting one complete working system, and then youd have a bunch of spare odd parts. What will you do with 4 air filter boxes?
Swapping the FI for carbs is a 2-3 hour process...its very easy. Locating correct, working parts can be...exhausting...
What should used, bolt-on, certified good D-Jet system be worth assuming nothing for your time to accumulate and test? Here is a general list, assuming that small unmentioned bits associated with larger bits are included and these parts can be found used at ebay prices:
Hardware:
25 Intake manifolds
25 Intake air plenum, TTS, TS1
50 Intake gaskets/air filter/fuel filter
25 Air filter housing/filter
75 Throttle body/TPS
Fuel:
40 Fuel pump
20 Fuel rails
20 FP regulator
50 New fuel lines/used clamps
FI components:
40 ECU
100 FI harness (used, minor repairs), ground lug
160 Injectors, cold start valve
80 MPS
20 New TS2
80 Dizzy/trigger points
20 Decel valve
50 New vacuum hoses
$880 SamoliansI Love the D-Jet...both my 74 cars have it still intact, I hope it lasts 4ever, but I know better. Carbs wont work as well as the D-Jet on a stock engine, and aftermarket FI systems, require sigificant dyno time to dial-in correctly.
Good luck finding a decent used harness, MPS, Dizzy especially ones for a 73-74 2.0. Near impossible, these 30 year old wires and parts are just plain 'at the end of their usable service life' and often require repairs or replacement. Certain parts are wear parts and will need to be replaced at some point...the TPS, MPS, injectors, filters etc.
