Full Version: Jack stands
spunone
Another stupid question from a novice.Where should you place the jack stands when supporting the car.I know under the jack points is one but where else on the unibody frame can I put them?. Thanks
ematulac
Check this thread.
lapuwali
Under the engine mount bar (if you're not dropping the engine). Under the front suspension cross tube (what the steering rack bolts to). Other than that, use the donuts, assuming the shell isn't rusty there.
