Full Version: Stock 76 914 2L
John VS
I have a 1976 914 2L that is stock. The engine runs great and starts right up when cold. After driving the car and the engine warms up, I shut it off and have a very difficult time restarting it. After it sits for a while and cools down, it starts up fine. Any ideas? Thanks, John VS
ArtechnikA
"they all do that"
starters have a hard life in the 914 - over the exhaust, behind the engine...
first, clean up all the grounds you can find, especially the transmission ground strap.
but probably, it's some combination of cooked grease in the solenoid and just wear. not too horrible to R&R the starter, thoroughly clean and re-grease the solenoid, and reassemble. that might work.
the ultimate fix is a genuine Bosch reman starter. and good electrical grounds everywhere...
John VS
The starter kicks over great, just the engine won't start. Almost like its flooded.
opera guy
i have a 911s 1974 that does the same exact thing, its still not fixed, due to no time. its just opposite of flooding, its dry. i bet you're getting sparks, and motor turning over... just no fuel. check fuel reserve, a 2.5x2.5x2.5 inch box on the passenger side (get under the car and look up) its one of the things to check.
Stutgart46
Sounds to me like a classic case of "Vapor Lock". Where is your fuel pump located? I'm the farhtest from an expert but I have dealt with this problem before. I moved my fuel pump to the front and replaced the hoses and the problem cleared up. I have also heard that if you wait minutes it will start right up. That seems to work, but who wants to wait aound for 30 minutes?
Good luck, I'm sure you'll get some great advice from some of the regulars here.
ArtechnikA
QUOTE(opera guy @ Sep 14 2004, 05:33 PM)
i have a 911s 1974 that does the same exact thing...
check fuel reserve, a 2.5x2.5x2.5 inch box...
a CIS 911 is nothing like a D-JET 914, however...
"fuel reserve" ? i have no idea what you're referring to ...
filter? accumulator? (D-Jet cars have no accumulators ...)
but back to the 914...
so here's another place where and accurate problem description would have saved some time... okay - the engine cranks but won't fire...
sounds like classic vapor lock, although a '76 should already have the pump in the front... still - when trying to start, turn the key on until you hear the fuel pump stop running. switch off, then back on. 5-6 times maybe. what you are doing is running the fuel pump to cycle cool fuel through the fuel rail and pressurising the system to purge the vapor bubble. try that...
if that doesn't work, make SURE you have a good spark. coils have been known to weaken when hot... any modifications we should know about ?
John VS
No modifications. Fuel pump is in the front. My son's mechanic looked at it and suggested holding down the gas pedal to the floor and start cranking. It took a few spins of the starter, sputtered and started right up. Drove fine after that. Sorry for not being more precise in describing the problem. Appreciate the responses. John VS
ArtechnikA
QUOTE(John VS @ Sep 14 2004, 06:16 PM)
...suggested holding down the gas pedal to the floor and start cranking. It took a few spins of the starter, sputtered and started right up.
...Sorry for not being more precise in describing the problem.
sounds like it could have been vapor locked, or its close cousin - being flooded as excess pressure (from boiling fuel in the loop) leaked through injectors designed to hold back far less pressure...
holding down the pedal is the standard "flooded start" procedure. glad it's working for you !
don't worry much about the probpem description, it's just a hot-button of mine, because 914's are subject to both the "hot-won't crank" and the "hot-cranks won't start" problem - from different causes - and it always seems like the initial problem description send people trying to help chasing after the wrong set of symptoms...
sobolewski
Mine is a 72 with a 1.7 and I have the same problem. The only difference is my fuel pump is located in the engine bay. I am hoping that relocating the fuel pump to the front will solve the problem. Does anyone have an idea of what that would cost if done "professionally"?
Thanks!
RustyWa
I've got a '75 2.0L. If I've been driving and go into a store for like 30 minutes, come out and try to start the car...I'll sometimes get that "flooded" like start. I just put the accelerator to the floor and crank it until it starts. It runs a little rough at first but it settles out.
John VS
Well thats what I'll do from now on. I have had this problem before (several years ago) but now it seems worse. I had the injectors replaced a month ago and a complete tune up. New fuel lines throughout. Got it smoged (no problem, except that the smog shop fried my clutch on the dyno). All oil leaks fixed. New paint. Rennshift installed. This just bothers me. Thanks again. John VS
