QUOTE(sean_v8_914 @ Mar 2 2012, 10:00 AM)
AIR MANAGEMENT IS CRITICAL!!!
I cant see what Ron has fwd of his cooler...
Note: None of this is SCCA track legal. AX is ok in SSM.
The 917 was the inspiration for this outlet shape. Doing it again I wouldn't have cut those tabs on the trailing edge. They're constantly in the way (and get bent) when filling up with fuel jugs. That sometimes happens when you let your right-brain overcome your left-brain in the design process. In front of the cooler...
I'll see if there is a pic somewhere but it's very tight in front of a 15 gallon cell. Below's a sketch I drew up on a flight from Manila that defined the mod. A 28 hour flight is too long not to do some noodling over what to do with your 914 when you get home. Prior to doing aero research this sketch shows the hood vent way farther back than I built it. Air pressure increases the farther back you go on the hood with the strongest low pressure zone right behind the bumper. I made templates of the deflector plates you see sticking up along the leading edge of the outlet. That way I can slide in different height deflectors depending on the speed of the track. Perhaps this description will help until I find a photo.
The inlet duct goes all the way to the front bumper through the bodywork and is attached to the cooler frame. One caveat in this installation is that the cooler is so large (with the hose fittings) that the cooler, therefore the ducting had to be offset, which I don't think you can make out from the pix. I'd have had more room if I had used -16AN fittings rather than adapt to the -12AN, but the cost scared me away. Now I wish I had. I do use -16AN for the oil tank return line though. I'd like to have used -20AN for that one, but the space for it is very tight.
So to make both the hood outlet and the bumper inlet centered on the car, I had to fab the cooler and ducting to go slightly toward the driver's side on both. It added somewhat more time to the build.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
