URY914
Sep 14 2004, 07:56 PM
Does anyone have a picture of a lightened 2.0 rod?
Or a website that would have one?
I've searched all my stuff and can't seem to find one. I hate to have to go back through all my print material.
Thanks,
Paul
Bleyseng
Sep 14 2004, 09:24 PM
One with holes drilled in it?
Geoff
machina
Sep 14 2004, 09:48 PM
these thingies?
JoeSharpOld
Sep 14 2004, 10:03 PM
Gosh! I'am getting a woodie. I like things that are finished by hand. OOPPPSSS!
Joe
URY914
Sep 15 2004, 07:48 AM
I love things with holes drilled in them.
Jake, Brad, Racer Chris, others, whata think?
Thanks David.
Paul
ChrisFoley
Sep 15 2004, 08:11 AM
Those took some time, for sure.
Notice the groove in the big end and the ridges on the small end. A lot of material was removed.
I would think that for the time invested a set of Carillos or Pauters would still be lighter and definitely stronger.
machina
Sep 15 2004, 08:21 AM
QUOTE(URY914 @ Sep 15 2004, 09:48 AM)
Then your gonna like my throttle and oil cooler brackets
dr
thesey914
Sep 15 2004, 08:33 AM
Dr -that is one of the nicest custom throttle cable brackets I've seen
URY914
Sep 15 2004, 08:40 AM
Chris,
You're right. Cutting in the groove is a hand milling job right?
What about just drilling the holes and cleaning them up with a grinding wheel and stationary belt sander?
Paul
SLITS
Sep 15 2004, 08:44 AM
You run 'em in your engine and when the beams seperate at high rpm, you can have fun rebuilding it again
And while your at it, you might want to purchase 9XXAuto's high performance fuel rails and throttle bodies. <_<
maf914
Sep 15 2004, 09:09 AM
dr,
Nice brackets! Aluminum? What gauge? Thanks.
machina
Sep 15 2004, 09:19 AM
QUOTE(maf914 @ Sep 15 2004, 11:09 AM)
Thanks Mike,
I used 14 (.0641") gauge aluminum because I have very limited tools for working the metal. Basically a drill press and a saber saw.
I was worried about the rigidity of the throttle bracket but it is very strong, even with the lightening holes. You really can't feel it deflect when you pull side to side with a strong hand.
The cooler bracket as an assembly is also fairly rigid. I have plastic spacers between the cooler and the bracket and rubber sheet between it and the body. Feels very stiff, deflects the slightest bit side to side. maybe .05"
If the coolers do get wacked, at least they wont damage the body too much when they fail. If I used heavier stock, probably would rip the bottom of the trunk out.
dr
Aaron Cox
Sep 15 2004, 09:22 AM
dr,
that was an inspiration to throttle brackets all over the world
Brett W
Sep 15 2004, 09:27 AM
Check out these rods:
machina
Sep 15 2004, 09:28 AM
QUOTE(acox914 @ Sep 15 2004, 11:22 AM)
I always wanted to help mankind, guess the best I can do is a cool bracket.
Seriously, the whole thing arose from the fact that the linkage was already setup to pull from (behind). Every other 914 carb linkage I have seen pulls from the front. I had to figure a way to mount the cable head at the back of the case.
I know I could have swapped the linkage around but the motor was dyno'd with the current setup and I didn't want to take it all apart. There are enough variables already since basically I don't have any idea what I'm doing.
dr
Brett W
I want some
machina
Sep 15 2004, 09:30 AM
Looks like they will snap if you look at them too hard.
dr
URY914
Sep 15 2004, 09:36 AM
QUOTE(synthesisdv @ Sep 15 2004, 07:19 AM)
lThats what I can inspiration.
Now can we get back to my rods.
Paul
machina
Sep 15 2004, 09:39 AM
QUOTE(URY914 @ Sep 15 2004, 11:36 AM)
what rods?
also, don't any of us work???
Should we be thinking about rods and holes on a weekday?
dr
Aaron Cox
Sep 15 2004, 09:41 AM
QUOTE(synthesisdv @ Sep 15 2004, 08:39 AM)
what rods?
dr
what a fitting topic for HUMP day
URY914
Sep 15 2004, 09:42 AM
QUOTE(synthesisdv @ Sep 15 2004, 07:39 AM)
dr
I do work. But this is MUCH more important!!!
P
Dominic
Sep 15 2004, 04:18 PM
I have a question on 2.0 rods? Are most people using the stock rods when they build performance engines? Since there are not too many chioces.....What are you folks using?
I'm going to be running a C/W crank and JE 96mm flat top pistons on my 2056cc engine.
Jake Raby
Sep 15 2004, 06:34 PM
Almost all my engines use a Type I rod combo.... I have the cranks and pistons made especially for it.
The 2.0 rod is heavy and weak ane more expensive for a rebuilt set than a H beam rod set that is 400 grams lighter and will hold 200 more HP.
There are no aftermarket rods for the TIV using a stock journal unless you call Pauter ( I don't like theirs) or Carrillo ($$$ but worth every dime)
I am working on a 2.0 replacement rod that will drop right in, and also another version that is longer for better rod ratios.
BTW, if its a street engine the JEs may not be the best choice. The Keith Blacks are a much better street piston. They run quieter, burn less oil and are lighter- just as strong.
rhodyguy
Sep 16 2004, 08:17 AM
so the am 2.0 type 4 rods that cb and aircooled.net sell are incompatible/won't work?
kevin
URY914
Sep 16 2004, 11:52 AM
Jake,
I gotta use my stock rods due to my 97mm Arias pistion's pin height which I posted about a few days ago. You said I need to get the weight down to 600 grams.
So looking I'm for the best way to do this. Grind and clean it up or drill some holes like the picture above?
Paul
