markyb
Mar 1 2012, 06:45 PM
Need a little help, is there supposed to be a washer under the nut that holds the rocker shaft to the stud? Also, any suggestions on which Loctite to use on this nut?
Thanks
mrbubblehead
Mar 1 2012, 07:44 PM
QUOTE(markyb @ Mar 1 2012, 04:45 PM)
Thanks
yes, a wavey washer. i am using nylock nuts and no loctite. i would use blue loctite if i had to.
markyb
Mar 1 2012, 07:51 PM
excellent idea, someone put standard flat washers on mine, and I would like a little more thread inside the nuts since I had to shim the rocker shafts.
I appreciate the help bubblehead....onward, time to finish this project!
mrbubblehead
Mar 1 2012, 08:15 PM
QUOTE(markyb @ Mar 1 2012, 05:51 PM)
good luck
sean_v8_914
Mar 2 2012, 09:48 AM
almost everything should have a washer under it. it increases the friction surface area and helps things stay together. also spreads the load of the fastener
Cap'n Krusty
Mar 2 2012, 10:54 AM
Remember, it's a SEVEN millimeter washer, NOT and EIGHT millimeter washer. OE is a spring washer, BTW.
The Cap'n
markyb
Mar 2 2012, 12:55 PM
Thank you, I'm looking for the spring washers, I have a shipment coming from Raby , they might have some old ones for me. I'll wait and finish the job correctly, no hurry, there's still a little road salt on the streets here in the Detroit area, no way my baby is gonna get any of that stuff on her.
