914itis
Mar 2 2012, 07:51 PM
I was putting all my harness together ready to mount my engine in the morning, I have the 13 pin connector with a relay at the end, I was thinking that it was that smog relay that weas discussed here recently, I googled the part number and it came up as fuel pump relay, . isnt the fuel pump relay on the relay board?
the part # is 0 332 514 120
cwpeden
Mar 2 2012, 08:02 PM
What kind of car are you working on?
That may be for the subie....
a914622
Mar 2 2012, 08:08 PM
Must be a 75? is that the one under the pass seat? I did the same thin and had to wire it back in.
Nope thats not a subi.
Valy
Mar 2 2012, 08:20 PM
It's the L-jet fuel pump relay.
Hope it works cause new ones are $90.
But I thought you have D-jet
jim_hoyland
Mar 2 2012, 08:43 PM
The fuel pump relay on the relay board was replaced by the separate dual relay in '74 / '75 on the L-Jets.
BTW a loose connection will cause the fuel pump come to an abrupt stop. Also, the dual relay is grounded to a spade located in the middle of the engine case. If you disconnect it, fuel pump ain't gonna work....
914itis
Mar 2 2012, 09:28 PM
ok, I have 2 harness (12 pins) they are both the same with the relay. My setup is a djet. Can I just cut the part that goes to the relay and use that harness for the starter wire and the reverse light only?
type47
Mar 3 2012, 07:34 AM
That sounds risky to me. Doesn't that harness connect to the AAR, thermotime and MPS? I'm not sure but you could go to Bowlsbys site and see the D-Jet harness connections and compare to your harness to see if everything you need to connect to is available on your harness.
914itis
Mar 3 2012, 09:30 AM
I know about the tach wire, oil temp and all the other engine connectors, I was only referring to the relay wires only.
I found a diagram, I will work from that. thanks all
Mar 3 2012, 10:34 AM
Paul - One of my cars came with a bunch of parts. Make sure you PM me if you need something. No charge if I have it. Mark
ClayPerrine
Mar 3 2012, 10:49 AM
QUOTE(ppetion @ Mar 2 2012, 09:28 PM)
Please don't cut it. The engine harness on an L-Jet equipped car is different from the one on a D-Jet car. The L-Jet has the connection for the double relay (the part you posted), and does not have any wire for the D-Jet aux air regulator.
If you need a D-Jet harness, I will trade you for the L-Jet harness, including shipping.
914itis
Mar 3 2012, 11:00 AM
Ok
Drums66
Mar 3 2012, 03:05 PM
QUOTE(jim_hoyland @ Mar 2 2012, 06:43 PM)
......Ya it is!........& make sure it is grounded well
(metal upgraded to plastic?)
cwpeden
Mar 3 2012, 05:01 PM
ok I see, I assumed he was wprking with a 70 harness.
914itis
Mar 3 2012, 07:07 PM
QUOTE(ClayPerrine @ Mar 3 2012, 11:49 AM)
Clay,
I have two, I will send you a set, PM me your address
ClayPerrine
Mar 3 2012, 11:12 PM
QUOTE(ppetion @ Mar 3 2012, 07:07 PM)
Clay,
Ok.. I will have to dig thorough my spares to find a D-Jet harness to send back.
