Lightweight_911
Mar 3 2012, 04:37 AM
Can someone post a picture (or two) of an original air cleaner (top part) inc 'snorkel' ?
I know 911 parts can be fitted but I am interested in how the original 914/6 version looked.
IronHillRestorations
Mar 3 2012, 07:51 AM
I'll see if I can get my hands on one. The 914-6 part is plastic, and slightly flatter across the top.
toolguy
Mar 3 2012, 09:15 AM
Your wish is my command. . . I've been putting off trying to figure out how to restore this part. . . got me stumped for now. .
ClayPerrine
Mar 3 2012, 10:52 AM
QUOTE(toolguy @ Mar 3 2012, 09:15 AM)
I would double check that and make sure it is OEM 914-6. I see the "fire starter" fuel line for MFI on that air cleaner. And unless it is from a 916, there should not be any MFI fittings on it.
campbellcj
Mar 3 2012, 10:58 AM
I have one in my garage someplace. I suspect it is paintable if you use a plasticized/flexible paint of some sort, like the Wurth trim paint.
sixnotfour
Mar 3 2012, 01:34 PM
Clay they actually did have the fire starter /cold start , It was quickly removed, by everyone.
avidfanjpl
Mar 3 2012, 01:42 PM
I had Embee Performance take my 914-6 air cleaner assy and the metal rain hat racks underneath to black satin powdercoat all after they were originally done by THOMAS to redo them due to a lot of scratches before the car got running
They turned out fantastic.
Powdercoating in black satin is wonderful.
J
Mar 3 2012, 05:55 PM
Is that metal or plastic Toolguy? 914-6 part is plastic
toolguy
Mar 3 2012, 07:56 PM
It's the black plastic box, not the metal 911 box. . it's been wrapped up for over 30 years. . . .
Eric_Shea
Mar 3 2012, 08:33 PM
my six had all of that stuff still hooked up along with the decel valve thingy.
Andy, what makes this different moreover is the snorkel. On a six (as you can see in the pictures) the snorkel hangs to the passengers side. The above box and snorkel are 914-6. I believe there's a hose fitting at the base so you can't turn it over. (maybe not... memory not serving me well)
Lightweight_911
Mar 4 2012, 04:57 AM
Thanks Eric - that's what I wanted to hear.
I'll post pictures tomorrow of the one I have.
Luke M
Mar 4 2012, 08:07 AM
QUOTE(ClayPerrine @ Mar 3 2012, 09:52 AM)
I removed my org. 6 air cleaner and looked just like Dave's ( toolguy ).
My car was untouched until I got a hold of it. Yes, it's made of plastic.
I have since sold the intake but have pics of it.
Luke
Lightweight_911
Mar 5 2012, 05:04 AM
maxwelj
Mar 5 2012, 12:15 PM
QUOTE(Lightweight_911 @ Mar 5 2012, 05:04 AM)
Mine doesn't have that pipe on the bottom of the snorkle.
GeorgeRud
Mar 5 2012, 12:50 PM
Was that for a mechanical injected engine? I seem to remember that they had a preheater for the injection system. My original 70 914-6 has a plain tube without the valve assembly.
SLITS
Mar 5 2012, 01:26 PM
I was thinking MFI .... heater tube goes from HE to pump to Air filter ... moves the rack from rich to lean as engine warms up.
Probably used with later model MFI where the raw gas is shot into the middle of the stacks for start up.
But
I don't really know.
Eric_Shea
Mar 5 2012, 03:21 PM
Sixes have just the bare snorkel like Luke posted. Memory coming back.
JMKnight
Mar 5 2012, 11:49 PM
QUOTE(maxwelj @ Mar 5 2012, 10:15 AM)
This doesn't look anything like the one on my '70??
pete000
Mar 6 2012, 12:01 AM
This is on a car that was near perfect.
