QUOTE(rwilner @ Mar 6 2012, 09:28 AM)
QUOTE(scott_in_nh @ Mar 6 2012, 08:41 AM)
same experience here. FWIW swepco didn't cause any leakage...
Scott are you using swepco? Any improvement?
Not trying to hijack or open up this debate, just want the opinion of a guy I know + trust
Rich I use synthetics as often as possible and laugh at a lot of the pro and con opinions you see on the web - its oil not magic and not a curse.
The PO of my car put fresh swepco in my car just before selling it to me.
My trans is probably very typical of the semi-tired trans that (at a minimum) could use new 1st and 2nd gear synchros.
After replacing the shifter bushings, adjusting the linkage and the clutch and still not being happy with the way it was shifting I decided to try dino lube.
While I'll promise you it is still a semi-tired trans that is not the best shifter, it definitely and noticeably shifts better with the dino lube.
