Hi All,
Tonight I reinstalled my repaired speedometer,then the steering wheel and fired up the car after a few weeks of no action. Car cranked for longer than usual then started and ran well. I then thought that I smelled gas, turned my light on and looked in the engine bay and found the driver side injector towards the back of the car (sorry, yes I should know what cylinder that is...) leaking fuel. I can't tell if it is leaking from the hose connection or the injector itself, but it was building up quite a puddle so I killed the engine and mopped up the fuel and have a fan blowing the fumes out of the garage.
Can you tell me the proper way to diagnose the issue? I am assuming the better scenario is a loose hose connection. I have not pulled an injector before - I do have a Haynes manual. I have what appears to be the fuel lines with the braided cover - they appear to be in ok shape visually (but maybe not...) Any advice appreciated! Don't know the diameter of the fuel lines - perhaps a trip flaps is in order?
thanks
Reg
