ThinAir
Sep 16 2004, 08:59 PM
The steering shaft has a "grooved ball bearing" on it (that's what Haynes calls it). It's located "inside" the dash area, behind the steering column switch assembly so you don't normally see it. On every 914 I've ever driven, this bearing is really noisy and sounds like it's full of sand. Since I've got the whole steering assembly in pieces I figured it was a good time to lubricate this bearing to quiet it, but what do I use to lubricate it?
Aaron Cox
Sep 16 2004, 10:19 PM
wheel bearing grease? thats what i'd use
ThinAir
Sep 17 2004, 06:37 PM
Something that can be sprayed into the bearing seems a little more practical than wheel bearing grease.
Aaron Cox
Sep 17 2004, 06:41 PM
in pieces
then whats the big deal about using a finger in wheel bearing grease?
, did you pull the column housing etc?
