* ORIGINAL CALIFORNIA CAR
* FRESH CHEVY 350, 4 BOLT MAIN, 10.5:1 COMPRESSION
* CHET HERBERT CAM (LUMPY) I HAVE SPECS IF YOU WANT THEM (SOUNDS MEAN AT IDLE)
* PRO COMP 202 ALUMINUM HEADS
* ROLLER ROCKERS
* CUSTOMIZED COOLING SYSTEM WITH MEZZIER ELECTRIC REMOTE MOUNT, 55 GAL PER MIN WATER PUMP
* PRO COMP ALUMINUM AIR-GAP INTAKE
* EDLEBROCK 650 CARB
* BILLET DISTRIBUTOR
* POWDER COATED BLACK WIRE LOOMS TO MATCH THE BLACK POWDER COATED VALVE COVERS
* MSD IGNITION
* DUAL EXHAUST, CHROME TIPS, 3 CHAMBER FLOW MASTER
* CUSTOM CENTER CONSOLE WITH WATER TEMP, OIL PRESSURE AND VOLT GAUGES
* CUSTOM BILLET DASH INSERT
* CD / HEAD UNIT WITH AX PORT FOR IPOD
* CUSTOM FLOOR SPEAKERS AND SPEAKER COVERS
* NEW CARPET
* NEW HEADLINER UNDER THE TARGA TOP
* LESS THAN 500 MILES ON ENGINE .40 OVER
* ALUMINUM RADIATOR
* CUSTOM BILLET GRILE TO ALLOW MORE AIR FLOW TO COOL RADIATOR
* HIGH OUTPUT ELECTRIC FAN TO COOL RADIATOR
* CUTOM BILLET RADIATOR SHROUD
* 901 SIDE SHIFT TRANS / YES IT CAN HANDLE THE HORSEPOWER JUST CANT GET CRAZY OFF THE LINE. JUMP ON IT AT 2K PLUS RPM'S AND HOLD ON TIGHT.
* 4-LUG RIVIERA RIMS WITH NEW TIRES
* NEW WHEEL BEARINGS AND SEALS ALL THE WAY AROUND
* NEW SHOCKS AND STRUTS
* NEW PADS ALL THE WAY AROUND
* NEW ROTORS ALL THE WAY AROUND
* HAS BMW 3 SERIES FRONT CALIPERS
* ALL NEW WIRING FROM STEERING WHEEL BACK
* TACH HAS BEEN CONVERTED TO V8 SETTINGS / RECONDITION WITH NEW PAINT AND NEEDLE
* NO RUST...HELL HOLE IS PERFECT. IT HAD A SMALL NICKLE SIZE RUST SPOT ON PASSENGER FLOOR. IT WAS GRINDED DOWN AND GLASSED OVER
* NEW INTERIOR / BASKET WEAVE
* NEW DOOR PANELS
* JET BLACK PAINT (DUPONT BLACK WITH NO TONER), COLOR SANDED AND POLISHED
THE CAR IS RUNNNG GREAT!!!
SHE RECENTLY WON FIRST PLACE IN A CAR SHOW SPONSORED BY THE CELEBERTY CAR BUILDER, BARRY WHITE, FOR THE BEST FABRICATION. THE CAR IS A REAL HEAD TURNER.
SUMMER IS COMING AND DRIVING THIS BEAST WITH THE TOP DOWN YOU WILL BE SURE TO TURN HEADS.
13K OBO / I MIGHT CONSIDER PARTIAL TRADE (WILL HAVE TO DEPEND. I HAVE NOTHING IN MIND BUT THERE WILL HAVE TO BE CASH INVOVLED AS WELL)
909/ 471-2432
EMAIL OR TEXT IS BEST
EMAIL ME IF YOU WANT BUILD PICS
- it's NOT ok to contact this poster with services or other commercial interests
View the full article
THIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
