Hello guys.
This morning leaving the garage I depressed clutch pedal and heard a snap. Pedal now feels spongy and clutch does not disengage. I prayed it was only the cable but when removed looks fine. I suspect the dreaded clutch tube failure.
My question is how can you tell before cutting up the tunnel. And how do you fix it if it broke loose. I will need to know were exactly to cut in to get to the right spots. Appreciate the advise.
